Ezviz C6N fails to upgrade firmware
attilhacks
Mar 15, 2021
6
2
italy
Hello, I have different C6N, TY1 cameras which fails to upgrade form the APP (both IOS or Android), and from Ezviz studio, nor from Ethernet of WiFi.
The new app won't display the camera if not upgraded to the latest release
any hints?
thanks
any hints?
thanks
Hey did you manage to fix this?
Looks like Ezviz finally fixed it, there is a "later" message instead of "exit" if you don't upgrade, and now I have been able to upgrade 2 cameras so far with a newer release. They must have noticed the bug
Reactions: rollsfrost
hi, i have 5 cams work good, but in setting some of them display (Local Operations) and other not, see attaché pic pleases.
how to display (Local Operations) in other ?
by the way i add 2 line in AppConfig.ini :
[LocalOperation]
Show=1
Thank you
