S servicekrunk n3wb Sep 19, 2016 22 3 Jan 7, 2025 #1 Is it possible to add ezviz cameras to the eufy app? Thanks Reactions: mat200
mat200 IPCT Contributor Jan 17, 2017 18,512 31,041 Jan 7, 2025 #2 servicekrunk said: Is it possible to add ezviz cameras to the eufy app? Thanks Click to expand... Hi @servicekrunk EZVIZ = brand of Hikvision ( Hikvision OEM ) EUFY = cloud cameras I do not know, however my bet would be no as most cloud cameras and their apps are "closed system" Hopefully, someone with more knowledge will reply with a more definitive answer
J johnfitz IPCT+ Member Feb 4, 2021 1,797 1,746 NY Jan 7, 2025 #3 I'm sure you have a reason, but why not just use the EZ-Viz app?
S servicekrunk n3wb Sep 19, 2016 22 3 Jan 7, 2025 #4 johnfitz said: I'm sure you have a reason, but why not just use the EZ-Viz app? Click to expand... My ezviz cameras are dying and am tired of connectivity issues, and warranty and replacements. I jumped to eufy on a recommendation and have been very happy. Will replace all Ezviz as they die but don't have budget to jump all in eufy now. Reactions: johnfitz
