Hi!
I ran into a problem after moving, that when I access UI or the app, it's loading extreeeemely slow if I'm connected to my home network, but accessing the domain I've setup (and always used, just updated the fixed IP).
If I access the local IP, loads with no issues.
If I disconnect wifi and just use my phone's data, it loads with no issues as well- Same domain etc. that I'm entering, only difference is the provider.
I remember having this issue quite some years ago, but I've tried almost everything and can't crack the code again. Does anyone have any tips?
Remote wizard runs through with all green checkmarks, since it does work, we're just talking 1~ minute before it logs in, then it has to load cameras etc..
I could just not care, but there's no reason in not using the wifi when I'm at home, so the data usage doesn't go crazy on my subscription
