I have BI4.4.0.2 with 6 ONVIF cameras running on an I7. I want to trigger video recording using switch contacts feeding a Sealevel 120 POE. Switch contact closures causes the proper response on the SeaMax utility. When I go into the Digital I/O tab, check Open Sealevel SeaDAC device and click "search again" and the correct IP address is filled in. Go into the Trigger tab for cam1 and set Global DIO input bits to 1. If I click "Trigger now" the camera triggers (red frame) and it shows up camera status log.
What am I missing here? Is there another box that needs to be ticed? Driveing me nuts!
View attachment trigger.pdf
Eric
Eric
