Hi everyone, I'm looking for some advice regarding terminating external ethernet on the second story of an under-construction contemporary ADU (Accessory Dwelling Unit). See attached pic. It's a flat roof with a parapet extending past the roof line by 1 and 2 feet.
The cladding is in the shou sugi ban style (charred timer). PoE cameras will be on all 4 corners. Aesthetics are important.
I'm heavily invested in the Ubiquity UniFi ecosystem. The rest of the house is full of their tech (switches, door access, access points, indoor cams, etc). I will likely go with their PoE AI Bullet which supports the ethernet cable entering directly through and behind the mounting shaft or entering at the side of the mounting plate.
I'll be running the ethernet in conduit to the corners.
Questions:
I'm looking forward to your feedback!
Questions:
- I'm thinking the cameras will be mounted on the verticle cladding. The ethernet will terminate near the corners (female). I don't want the ethernet cable sticking out as the cameras may not go up right away. They may also need to be removed in the future (privacy-related concerns for tenants and owners). What can I use to do this? Ideally, it would be something small and round that sits flush and has a weatherproof cover. I found bulkhead couplers that are designed to be used with a junction box. I suppose I could recess the junction box and plate and clad over it just leaving a hole for the now flush coupler with cap. What do you think?
- Would it be better to parapet mount it on an arm that hangs over the edge along the sides that have the most open space? And use a dome camera?
