Does anyone know anything about AP antenna placement for optimal performance?
I just added a TP-Link EAP225 high up in the middle open section of my attic to be able to get a better WiFi signal throughout and around the house. It works but not the range I was expecting. I have a lot of the usual home barriers to signal, walls, some wood, some brick, multiple floors so I get that.
The AP is an omni-directional but It comes with 2 long antenna attached to the top pointing straight up. They can both be independently rotated 360 deg and folded up to 90 or so degrees to point in almost any direction. I could not find any information in the instructions or much online about optimal direction pointing of the antenna.
When doing a walk around I found my signal is actually better (using an android phone Wifi analyser app, no idea of the quality there) outside of the house near the road 20 yards away than in some areas of the house.
Are there any standard guidelines for how to adjust these for maximum performance, (stronger strength in the house and additional range outside the house) or should I just leave them both straight up?
