Exposure 3D and 2D settings explanation?
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
Can anyone explain the function of these two settings and the recommended Day and Night settings for each. I can't seem to find much information on these. Thanks
2D is meant for noise reduction of static objects and 3D is meant for noise reduction of moving objects.
But like everything it comes down to your field of view and other parameter settings.
In theory having both allows for stationary objects to run a different noise reduction and allow 3D to just focus on moving objects.
Some can drop 2D to 15 and 3D at 30 and get great captures while others have to have the numbers be the same, and everywhere in between.
Like everything, play with both and test it with moving objects. You should take NR down as far as you feel comfortable
Thanks @wittaj, I think I'll try the 2D to 15 and 3D at 30 setting you mentioned and go from there. Much appreciated!
