Hi,
i helped someone set up some ds-2cd2032-i cameras for his liquor store and he wants to search and export clips from the recordings. so i know that all the videos get saved in the harddrive as 1GB files thats about 24 hours long. let say for example theres a theft that occured between 1:00 to 1:30. he would just want to search that time frame and export that to a file and give to the authorities.
as of right now, i dont see any options for doing that. hes using the ivms-4200 software, under remote playback, there is nothing. which is odd. the only way he can playback anything is if he goes to file -> open video file. and hes also not able to search by short time frames. so for example 11/20 1:00 to 11/20 1:30 would not work, however 11/19 to current will work. but again he only wants a short clip.
hope this makes sense. i REALLY need to get this to work for him. any help is much appreciated. thanks!
