Using a Dahua 16 port POE NVR with 4 wired Dahua cameras on the POE ports. Have an application to add another 4 cameras to a location 200 feet away.
Reviewing Ubiquiti, EnGenius and Mikrotik for the appropriate 5 GHz full duplex micorwave link system.
The remote side will consist of one half of the RF link, POE adapter to power the link plus a 4 port POE switch to combine the data from the 4 cameras plus camera POE power.
Looking for suggestions on a good way to add the 4 remote cameras to the NVR. Channels 1/2/3/4 are in use for the wired POE Dahua cameras. The remaining 12 ports are not in use. The NVR has one 10/100/1000 Ethernet port.
The NVR Ethernet port is presently connected to a 4 port router to allow local/internal access for playback, live view and camera settings using Smart PSS on two desk top local Window computers.
It is a matter of adding a 4 port switch or router (wireless not desired) to the NVR side? If so, how are the additional ports of 5/6/7/8 assigned in the NVR to the appropriate remote cameras when using the switch or router connected to the NVR Ethernet port?
Any suggestions are most appreciated.
Jim
Jim
