Hello All,
I have been trying to find a solution to this for some time, but nothing so far. Way too many event emails! Not due to sensitivity, but redundancy, many emails for the same event. I have tried to use event email from both the camera and nvr. The camera works a little better because you can control the quality of the image. However in both cases, the only setting I can find to limit the number of email you get around an event is the Interval select box in the Network -->Advanced Settings -->Email section. The select list only has options from 2 to 5 seconds. So if I happen to jump in my car in the garage during the 'armed' schedule, I may get 6 email if it takes me 30 seconds to get going.
Any advice would be appreciated!
Thanks.
Camera
DS-2DE3304W-DE
V5.4.8 build 170210
NVR
DS-7608NI-E2 / 8P
V3.4.92 build 170518
Thanks.
Camera
DS-2DE3304W-DE
V5.4.8 build 170210
NVR
DS-7608NI-E2 / 8P
