Hi all,
I just built a new home and had run some cat 5e to different locations for ip cameras. I recently installed the actual cameras and in one location I feel like I could benefit from an additional angle/camera. Problem is I only ran a single cat5e to this location. The second camera I want to add would be in the same soffit as the first, so I'm wondering if I can use an Ethernet splitter to get 2 camera feeds.
My understanding is that IP cameras are 100 base-t devices (not gigabit). If I'm not mistaken, don't 100 base-t connections only use 4 of the 8 wires in the Cat5 cable? If that's the case, can't one use a splitter on both ends of cable run to effectively create 2 feeds?
The one thing I don't know is if a 100 base-t connection with POE uses more than 4 of the wires in the cable? If so, then a splitter can't work. I haven't been able to find the answer online so thought I would ask...
FWIW, I know I could install a cheap $25 Ethernet switch in that soffit (steal a power feed from a nearby light or something), but the problem with that is I live in Atlantic Canada where our winters are pretty brutal (-15F to -20F is seen in January) and a reasonably priced switch will not perform in an unheated soffit.
Thank you
Jeff
Thank you
Jeff
