Hello, I wonder if anyone here can tell me what this error msg means in my asus ac3200 router. (The bolding is mine) I just noticed it today when I was looking at some other things. I'm using Openvpn.
Dec 14 16:57:05 rc_service: udhcpc 26046:notify_rc stop_upnp
Dec 14 16:57:05 rc_service: waitting "start_firewall" via udhcpc ...
Dec 14 16:57:06 rc_service: udhcpc 26046:notify_rc start_upnp
Dec 14 16:57:06 rc_service: waitting "stop_upnp" via udhcpc ...
Dec 14 16:57:09 vpnserver1[26133]: WARNING: POTENTIALLY DANGEROUS OPTION --verify-client-cert none|optional (or --client-cert-not-required) may accept clients which do not present a certificate
Dec 14 16:57:09 vpnserver1[26133]: OpenVPN 2.4.7 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 1 2021
Dec 14 16:57:09 vpnserver1[26133]: library versions: OpenSSL 1.0.2u 20 Dec 2019, LZO 2.03
Dec 14 16:57:09 vpnserver1[26134]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Dec 14 16:57:09 vpnserver1[26134]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Dec 14 16:57:09 vpnserver1[26134]: Diffie-Hellman initialized with 2048 bit key
Dec 14 16:57:09 vpnserver1[26134]: TUN/TAP device tun21 opened
Dec 14 16:57:09 vpnserver1[26134]: TUN/TAP TX queue length set to 100
Dec 14 16:57:09 vpnserver1[26134]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Dec 14 16:57:09 vpnserver1[26134]: /etc/openvpn/ovpn-up tun21 1500 1622 10.8.0.1 10.8.0.2 init
Dec 14 16:57:09 vpnserver1[26134]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
