Error: 80002af9 (Failed to connect) 0
wepee
Jul 16, 2016
263
60
Hi All,
I did not have such a problem before, It was working fine.
BI System was shut down and all the main power was switched off before I left in my shop.
Out of the blue, when I switched on the main power this morning, BI system started to kick in,
Everything is running ok, however I notice this error: Error: 80002af9 on my BI console.
I saw 1 Foscam camera not connected to BI. I have a total of 4 cameras, 1 IMOU and
the other 3 are Foscam.
As far as I know, my camera still can access via the old IE web interface.
No issue at all. It is working fine. See below:
But BI refuse to cooperate, and it won't connect my Foscam camera
I search the forum and I referred to this post for solution but no avail. My Foscam camera is reachable by using IE but not BI.
I have done the following steps:
1) Rebooted my BI system
2) Rebooted my wifi client that is connected to my Foscam camera
3) Rebooted my Foscam camera
4) Exported the old camera's settings
5) Delete the old camera from the BI console.
6) Create a new camera by importing the old camera setting
Result: Still showing No signal
Do I need to rebuild BI system again in order to solve this problem?
Thank you.
Hi All,
Out of the blue, when I switched on the main power, my BI system started to kick in,
.View attachment 145122View attachment 145121
Thank you.
What version of BI. What ip is displayed in the video tab?
If its still not working, try adding a "new" camera without importing the settings and see if that works.
Reactions: wepee
Thanks ! It is working now
What could be the reason? The database got corrupted due to improper BI shutdown?
Reactions: fenderman
I dont know. Sometimes we see corruption in the camera setup (maybe a registry issue) and deleting the camera and adding it back resolves it.
This is the only camera that I was testing with CodeProjectAI
Luckily I was just tested it, if not greater problem will occur.
Sort of related, I recently set up CodeprojectAI with a single camera on my 25 camera system. I changed my BI setup to use GUI and that single camera would not work. Fortunately doing another Find/inspect got it back online. Thanks Fenderman for getting him going.
Reactions: fenderman and wepee
