- Jun 12, 2014
- 14
- 0
Not just a high definition IP camera, but also a smart security system. eRobot series IP cameras are designed for home and business monitoring. The system replies on smartphone App to provide you the simplest and reliable security solution including real time remote view and advanced intrusion detection.
eRobot D1201-A/B is a new design pan/tilt IP camera, it supports WiFi and LAN network connection, built-in ICR filter and IR illuminators (two) to provide day/night video monitoring. It has built-in microphone and speaker, supports two-way audio intercom. You can connect with your families with HD video plus audio. Included TF/MicroSD card slot, video and events can record on SD card locally, you won't miss anything important.
Different from other traditional IP camera, D1201-A/B has built-in RF receiver interface. Just like your wireless home alarm system, it has 8 wireless zones, and works up to 64 wireless sensors. To extend the system, you can use Wireless Door/Window Reed Switches to protect each of your residential doors/windows, wireless passive infrared motion sensor to protect interior area, even some wireless smoke sensors for fire detection.
How to arm/disarm the system? The eRobot IP camera can allow user arm/disarm the system through smartphone remotely, also it works with remote keyfob, when you leave home, just press "Arm" key to activate its intrusion detection function. When you arrive home, you just need to press "Disarm" key to deactivate. Additionally, D1201-A/B supports video analysis based motion detection. Once system detects these abnormal events, user will be notified immediately with push notification or emails (attached with snapshots). The system will use speaker as its internal siren to deter intruders.
The system's remotely view will not let you down. You can access the IP camera through smartphone, PC software, IE browser. Since it is based on "Peer to Peer" technology, you don't need to use DDNS or port mapping for network connection. Plug your camera to home router, then register account, add your device, only three steps. Your eRobot IP camera is ready to use.
D1201-A info: http://www.hkvstar.com/item/erobot-wifi-wireless-pan-tilt-ip-camera-2.html
D1100 info: http://www.hkvstar.com/item/erobot-ip-wifi-home-security-camera-with-pir-sensor.html
D1000 info: http://www.hkvstar.com/item/smart-wifi-ip-camera-for-home-and-shop.html
