Equivalent web interface button that allows viewing of all clips on the screen at once.
koops
May 13, 2020
24
14
Australia
Within the normal console view of blue iris there is a button that allows viewing of all clips.
The button looks like a folded map.
Pressing this button will then expand the clips window to fill nearly the entire screen which allows for quick visual scanning of all clips.
Is there an equivalent method to allow a similar "all clips" view within the web interface?
I've looked through the web ui interface settings at all the "clip" options and nothing stands out that would allow this/enable this as far as I can see.
I've found searching through the small vertical scrolling window less than ideal with trying to visually search for something.
It likely exists I just can't find it. Thanks! :)
