- Feb 5, 2018
- 1,009
- 1,358
Tuesday: Lightning strikes the power lines on a pole right at the edge of our water plant's property. This takes out one fuse and one lightning arrestor at the pole, cutting one phase of the high voltage feeding the primaries of the transformer banks that feed both the plant and our "settled water pumphouse".
This also killed both of the loop detectors for our automatic gate and blew a surge suppressor on one of my boards that protect our PLC system and data acquisition system on a buried (4-20mA current loop) line from an electromagnetic flow meter in a pit a few hundred feet from the plant.
All of this was easy to fix or live without. The power company came out and replaced the blown cut-out on the pole, but did not replace the fried lightning arrestor.
With power restored, we got the plant back running, and started "making" drinking water for the town again. Fine.
Fast forward about 24 hours to the following afternoon. A small girl and her grandpa are flying a kite.
See where this is going?
The kite comes down right on the very place where lightning had hit the power line the day before.
Guess what? Kite frames are now made with carbon fiber struts!
Big flash, loud noise, excitement, and fun for all!
These tiny, thin, carbon fiber struts about 3/16" in diameter are blown into fluffy things that look about like a horse's tail in diameter. They hang across all three phases and intermittently short the phases as the breeze moves them near enough.
The vegetation below the power pole catches on fire. The fire department and police show up. Everyone has a fun time.
We call the power company, and the same guy from the day before comes out and pulls three fuses down the street at a ground box to kill power to our pole so he can get up there and safely remove the carbon fiber from the wires.
He then replaces the blown cutout, and, at our suggestion, also the surge suppressor.
He then replaces the fuses down the street, and everything looks OK, so he leaves.
But our phase monitors keep tripping intermittently, so we check all three phases on the 480V side of things in the plant. Sure enough, one phase is intermittent, and shows widely varying voltage.
We call the power co again, but the first guy is off for the evening, so they send out another guy.
At first, he says the power reads within their tolerances, and prepares to leave. But we insist that it's intermittent, and that our readings show one phase to be bad.
I suggest that he check where the fuses were pulled and replaced down the street because it appears that one fuse is not making good contact. He scoffs, but checks it out anyhow.
He comes back about an hour later and says when he approached the box, he could hear arcing and smell it. He said the Blue light coming out of the box was pretty spectacular.
He went further down the line to de-energize that box, and replaced the now-fried fuse. He brought it with him, and it was pretty impressive!
At this point, the power was good. But the "brownout" effect on that particular phase caused a switching power supply in a fancy controller for a pair of turbidimeters (on-line water quality instruments) to roast. Lots of bulging electrolytic caps in that baby!
I replaced that controller with a spare I had repaired a few years ago, and by midnight that night, we had the plant running once again.
Wish us luck for the future!
