I have been successfully using one ethernet Hikvision PTZ mini dome camera interfacing to a dedicated computer running Blue Iris 5 undder Windows 10 Pro since October 2019. My configuration is an Arris Cable modem wireless router combo with the dedicated computer attached to the network wirelessly. The camera was connected with TP-Link adapters to provide ethernet over power plugged into an ethernet port on the Arris router. At the other end is the paired TP-Link adapter connected to an ethernet unmanaged POE router and then the camera is also plugged in to that router. The two TP-Link adapters are on the same circuit (breaker). I had to go this routes due to logistics related to thr location of the Arris router and the POE router. This configuration worked well from October 2019 until February 16, 2020 when one of the TP-Link modules started experiencing problems and I could not access the camera through a browser or Blue Iris. I have since gotten rid off the TP-Link modules and installed a wireless network extender which is connected to the POE router with an ethernet cable. I still cannot access the camera from the dedicated computer, however if I ping the IP address of the camera from the dedicated computer I get responses back from the camera. On Blue Iris I get a message "Cam1: error 8000274C - No signal". In the web browser (Firefox and Microsoft edge) I get waiting for 192.168... and ultimately it just times out. On another computer connected wirelessly to the Arris router I can connect to the camera and see the video and change configuration with no problem using Firefox. I can also connect my cell phone to the Arris router and using Chrome browser I can connect to the camera and see the video with no issues. Also on the dedicated computer I can connect through the Arris router and surf the internet with no problem. However, I decided to rule out the USB wireless adapter and hardwaired the dedicated computer to the Arris router by running a ethernet cable from one room to another and eureka, I had video in Blue Iris. Since I couldn't leave the temporary cable run between the rooms I decided try the TP-Link units again for a much shorter distance and when I did I stopped getting video again so I went back to the temporary ethernet cable and this time I could not get to the camera again no matter what I tried.I am really at a loss. In researching one issue that was raised that could cause this error was related to Windows 10 and I got to thinking that I had updated to the latest version 1909 November 2019 update. So today I reverted back to pre 1909 state, I still cannot see any video and still get the Cam1 no signal message without an error code. It almost seems like whatever path (wireless first thenethernet cable second) I used to go to the camera through the TP-Link units have been blocked by Windows from receiving any data from the cameras
Anybody have any ideas on what maybe wrong? Any and all help is appreciated. Thanks.
