- Oct 20, 2015
- 65
- 9
Is this possible? I have 2 PTZ cameras out front and since installation they have operated primarily based on smart event > intrusion > smart tracking. I've enjoyed this performance but it is not without flaws...
I have since moved to the BI world and simply love the AI filtered events, but they are troublesome when used in conjunction with PTZ smart tracking for the following reasons;
Is it possible to set up BI and a PTZ camera like this;
1) PTZ parked at Preset1 with camera level motion detection disabled.
2) BI level motion detection and Deepstack running 24/7.
3) When an AI confirmed alert occurs (eg; person, 80%), the cameral level motion detection is enabled, which in turn enables smart tracking for xx seconds.
4) After xx + y seconds, disable camera level motion detection and return to Preset1 (if not already).
On my Hikvision, the option is simply a checkbox "Enable" which brings into effect the motion detection and Linkage Method > Smart Tracking.
Is there any way to get BI to check that box and save? then uncheck and save?
- Camera movement from smart-tracking will give false positives on static objects, like parked cars.
- Camera movement and zoom / focus, during jpeg capture, often leads to blurry images and missed events on Deepstack analysis.
