I won't be able to purchase for about 45 minutes. Hopefully it will still be in stock.The stock only 1 left now, please try to make asap, new stock still not know when can be ready.
aha, should be OK! No hurry.I won't be able to purchase for about 45 minutes. Hopefully it will still be in stock.
Don't want to dissuade you from the Hikvision model if that's what you're specifically going after, but FWIW Dahua has a similar model (5442TM-AS-LED: 4MP 1/1.8" sensor, Full color, LED lights) that they show is compatible with the PFA-130E bracket that you have. Andy's OEM version looks to be $20 cheaper than the Hikvision model.Thank you! I'll order one today and test it out on the Dahua bracket and report back.
Tech sheet shows the PFA-130E compatibility:
Camera review, FWIW:
Review IPC-T5442TM-AS-LED (Full Color, Starlight+)
Dahua OEM IPC-T5442TM-AS-LED from EMPIRETECANDY 4MP WDR Turret AI Network Camera Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review. Andy's ipcamtalk vendor forum: link Andy's AliExpress store: link Andy's Amazon store: link Andy's Email: kingsecurity2014...ipcamtalk.com
Yes, that is right, We tested this 4mp hikvision one i think can be better than the dahua's 4mp LED model. Full color capacity, the colorvu is better.Interesting................................... I have four EmpireTech IPC-HDW5231R-ZE IP cameras and I generally love the low light performance but I was hoping for a bump in clarity the 4MP Hikvision seemed to resolve.
It appears the Dahua 5442TM you linked to has the same 1/1.8" sensor sensor as the Dahua 8MP models but I am guessing as it is 4MP the low light will be better than the 8MP but slightly less sensitive as my 5231's....
I was only looking at Hikvision b/c I didn't know about the Dahua.
I'll look at the review for the 4MP Dahua
Thank you!!
Just in case - this model does not see IR, it has a permanent IR filter to block it.never a need for IR for the placement I'm interested in
