Hi all!
I was thinking of building a blueiris pc but I think ill be better off with an empiretech NVR, my question was if anyone else ever tried pairing the empiretech AI nvr with a z12e s2? and is it possible to have license plates saved to the NVR and the DMSS app like the LPR and ANPR cameras store them? as in do I need on board AI inside the camera or can the NVR carry out the job of storing plates like blue iris would. Thanks!
NVR in question:
empiretech01.com
z12e-s2:
empiretech01.com
actual LPR that i want to mimic:
empiretech01.com
NVR in question:
EmpireTech NVR8CH-8P-2AI 8 Channels 1U 8PoE 2HDD Network Video Recorde
Max. decoding capability: 32 × 1080p@30 fps or 8 × 8MP@30 fps. Max. 384/384/384 Mbps incoming/recording/outgoing bandwidth Supports IP cameras with a resolution up to 32 MP Supports AcuPick with up to 8 channels Supports N+M cluster, iSCSI AI by Recorder AI by Camera Supports EPTZ, and one-click...
empiretech01.com
z12e-s2:
EmpireTech IPC-B52IR-Z12E-S2 1/2.8" CMOS 2MP 5mm–60mm Ultra Low Light
2MP 1/2.8" CMOS image sensor Built-in IR LED, the max. illumination distance is 150 m Deep learning algorithm Built-in MIC IP67 and IK10 protection SMD 3.0
empiretech01.com
EmpireTech LPR413-Z3 1/1.8" CMOS 4MP Starlight+ 8mm–32mm Vari-Focal Du
4MP 1/1.8"CMOS License Plate Recognition Distance Distance up to 20 m (65.62 ft) Capture and Recognize License Plates from Vehicles Traveling up to 120 kph (75 mph) Starlight+ Technology, dual Illuminators Supports Intrusion and Loitering Detection Built-in Mic and Speaker Active Alarm with...
empiretech01.com
