H. Swanson Pulling my weight Nov 3, 2023 169 127 Tennessee Nov 17, 2023 #1 I want to install my turret cam using the wall mount but the notch is on the wrong side for running the cable up my downspout. I’d have to run it around the mount. Has anyone drilled a new notch on a mount before?
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,343 48,164 Alabama Nov 17, 2023 #2 Pretty sure you can rotate that, I've haven't had a problem. You said "....for running the cable up my downspout" ; You're going to have the notch facing down, correct?
H. Swanson Pulling my weight Nov 3, 2023 169 127 Tennessee Nov 17, 2023 #3 TonyR said: Pretty sure you can rotate that, I've haven't had a problem. You said "....for running the cable up my downspout" ; You're going to have the notch facing down, correct? Click to expand... This is for the wall mount PFB203W. You can’t rotate it. The notch is only on one side and that’s it.
F fergenheimer Getting comfortable Oct 19, 2018 445 954 SWTexas Nov 17, 2023 #4 Yeah, I have. I ran some wiremold like this Legrand Wiremold 700 Series 5 ft. Metal Surface Raceway Channel, White BWH1 - The Home Depot to it. I used a deburring bit like Drill America 1/4 in. x 5/8 in. Tree Radius End Solid Carbide Burr Rotary File Bit with 1/4 in. Shank DULSF1 - The Home Depot to form the hole. Then I caulked it to make it water tight. Reactions: TonyR
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,343 48,164 Alabama Nov 17, 2023 #5 H. Swanson said: This is for the wall mount PFB203W. Click to expand... That's handy info....no, I guess you can't.
F fergenheimer Getting comfortable Oct 19, 2018 445 954 SWTexas Nov 17, 2023 #6 I replaced that camera with another mount. This one replaced it so you can get the idea. Attachments IMG_20231117_200644.jpg 1 MB · Views: 46
H. Swanson Pulling my weight Nov 3, 2023 169 127 Tennessee Nov 17, 2023 #7 Thanks for sharing Reactions: fergenheimer
