OK so I have my ERL set up with WAN+2LAN. I have my home and guest network on LAN 1 and the BI CPU and cameras on LAN2. VPN installed and connectable. Everything works great and BI sees the cams.
I was following a tutorial for putting the cameras on their own VLAN on the ERL and switch and blocking anything incoming or outgoing but it was for a Mac using security spy so I couldn't get BI to see the cameras after putting the cameras on the VLAN and adding the VLAN info on the BI nic.
Instead can I just set up firewall rules per camera mac address to just drop everything in/out but OK it for the local?
