I just ordered my first Hikvision camera, a DS-2CD2432F-IW. I have been doing a lot of research, but can not conclude what the easiest method is to achieve the setup I would like. I currently use a Logitech Alert solution that will sync all recorded clips from the camera sd card to a local PC through the Alert software loaded on the PC. I then integrate it into my z-wave solution through a script that wil search the clips on the PC and copy out the latest few based on a z-wave trigger event. For archiving purposes these clips get stored into a folder that synchronizes with a cloud file share.
Would anyone have suggestions on the easiest way to automatically sync the clips recorded on the sd card from motion events on the Hikvision to a PC?
