D dorado cams n3wb May 13, 2022 2 2 Gold Coast May 13, 2022 #1 Hello, I have some sensor data coming in on a UDP port on the host computer I have my cameras/Blue Iris running on. Is it possible to have that data displayed (and updated dynamically) within Blue Iris? Any help much appreciated. Thanks
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 22,062 52,236 Alabama May 13, 2022 #2 Yes, if..... By using Blue Iris Tools, if your program can write that value into a text file, then you can create a macro in BIT to display it. More info here in Blue Iris Tool Help => Weather Overlay P.S. - Welcome to IPCT ! Reactions: sebastiantombs
D dorado cams n3wb May 13, 2022 2 2 Gold Coast May 13, 2022 #3 TonyR said: Yes. By using Blue Iris Tools, if you (the program) can write that value into a text file, then you can create a macro in BIT to display it. More info here in Blue Iris Tool Help => Weather Overlay P.S. - Welcome to IPCT ! Click to expand... Thanks Tony, I did some testing and that will work great! Reactions: sebastiantombs and TonyR
