Hi there,
I have a Hikvision NVR DS-7608NI-E2/8P/A
1 x DS-2CD2042WD-I (Mini Bullet)
1 x DS-2CD2142FWD-I (Dome)
1 x Chinese PIR style spy-cam
Thanks for reading this post. I have a question about Dynamic Analysis for Motion on Hikvision NVR's. I originally thought that Dynamic analysis for motion is what puts the green event markers on the blue video timeline whenever motion is detected. This is also known as the "smart" option in playback which is essential for quickly reviewing events and incidents. Anyone with a Hikvision knows how useful the green event markers are on the timeline.
The green event markers are being shown when motion is detected on both of my Hikvision cameras. In playback I can select the "smart" option so the needle jumps to where motion was detected thus skipping over the static parts.
As an experiment I've just bought a cheap Chinese spy-cam in a PIR alarm-style housing. Don't laugh - it's surprisingly good for £18!! It's 1080p and uses the ONVIF protocol. The image is clear although it's prone to the occasional bout of heavy jittering on the bottom half of the image when it detects movement. It connected to my NVR straight away. It has movement detection and the yellow event triangle appears on the Live View screen when I move in front of it.
However, no green markers are shown on the blue timeline to indicate movement. The timeline for my PIR spy-cam is a continuous blue line no matter how much I dance in front of the camera. This means I need to manually scroll through an entire days recording to look at motion events which ideally should all have a green tag beside them.
During my research I read a post where someone else thought Dynamic analysis was to do with the green markers that track movement but they said even with Dynamic analysis off they still have green markers on their timeline. They said Dynamic analysis is what makes the red squares turn green when you view the image in motion detection mode (the screen with all the small boxes on).
Is this because my £18 spy-cam does not have Dynamic Analysis for Motion? (even though it has motion detection which does work?)
Is the Dynamic Analysis for Motion feature camera specific?
How can I get the green movement detection markers on my timeline for my cheap Chinese import? Is there a way to get the green movement bars working with any camera that can detect movement (lets face it, motion detection is available on most cameras - even the cheap ones).
Any help or advice would be greatly appreciated.
Many thanks.
Esso
Many thanks.
Esso
