id-7208HUHI-K1/4S(B) updated with DVR-K8A3_EUROPE-ML_STD_V4.26.131_210811.
Update was OK error in loading shows insmod: can't insert 'extdrv/tp2823.ko': No such file or directory
Erasing cfg file ... Done
Writing ...
dav0-21-1. write uImage len: 5261360
dav0-21-2. write start.sh len: 9368
dav0-21-3. write hkmem_load.sh len: 8528
dav0-21-4. write player.tar.lzma len: 84928
dav0-21-5. write sys_app.tar.lzma len: 15176416
dav0-21-6. write gui_res.tar.lzma len: 2966520
dav0-21-7. write WebComponents.exe len: 2380784
dav0-21-8. write webs.tar.lzma len: 1283240
dav0-21-9. write i18n.tar.lzma len: 662296
dav0-21-10. write RSA len: 24
dav0-21-11. write new_10.bin len: 1576
dav0-21-12. write DSP1.bin len: 1966080
dav0-21-13. write rsa_result_p0.bin len: 256
dav0-21-14. write FD_Algorithm_model.bin len: 1600400
dav0-21-15. write rsa_result_p1.bin len: 256
dav0-21-16. write SMD_Algorithm_model.bin len: 15886008
dav0-21-17. write rsa_result_p2.bin len: 1024
dav0-21-18. write FRCNN_CLS_Algorithm_model.bin len: 56
dav0-21-19. write rsa_result_p3.bin len: 256
dav0-21-20. write FRCNN_Algorithm_model.bin len: 3306512
dav0-21-21. write rsa_result_p4.bin len: 256
dav0-21-21. write flag file /dav0/version.bin len: 4
Done
Checking ...
Done
Update successfully !
Press ENTER key to reboot
[ 198.733758] do_update(257) called reboot syscall, cmd: 0x1234567.
[ 198.741135] Restarting system. (task: do_update, PID:257)
SPI NAND
Flash ID read done
Normal Boot
[SECURE_INF]: Platform:0x20180a BuildTime:0x5e8f07de
[SECURE_INF]: [SECURE] <<< Check secure boot enable >>>
[SECURE_INF]: <<< Secure Boot >>>
[SECURE_INF]: loader ready to boot
Enter Loader
WATCHDOG RESTART
Version 0.3.8
done
DDR1 1800 2Gb
Uncompress from 0x100000 to 0x0, size 296096
U-Boot 2016.07-svn37416 (Apr 09 2020 - 19:32:18 +0800)
pwm read 5, set duty = 20
Hit ctrl+u to stop autoboot: 0
Loading file 'uImage' to addr 0x02000000...
Done
Verifying RSA ... OK
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux-4.9.44
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5261033 Bytes = 5 MiB
Load Address: 00008000
Entry Point: 00008000
Loading Kernel Image ... OK
Starting kernel ...
[ 4.099843] init(1) called reboot syscall, cmd: 0x0.
Thu Jan 1 00:00:04 UTC 1970
Starting udev: [ OK ]
UBI device number 0, total 832 LEBs (105644032 bytes, 100.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi0_0.
UBI device number 1, total 128 LEBs (16252928 bytes, 15.5 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
bootpart :0
/usr/bin/hrsaverify: verify "/tmp/start.sh" success!
/usr/bin/hrsaverify: truncate "/tmp/start.sh" to 9112(2398 hex) success!
Protect Shell (psh)
Enter 'help' for a list of DVR/NVR system commands.
# sdbg: serverip:192.0.0.128 who:
nfsdir: kdbg:1
language is 1
/usr/bin/hrsaverify: verify "/tmp/hkmem_load.sh" success!
/usr/bin/hrsaverify: truncate "/tmp/hkmem_load.sh" to 8272(2050 hex) success!
load hkmem start*
af37
DS_72_78_08HUH_M
cava_bin 0x0c000000 0x400000 dsp_ddr0 0xc400000 0x2AEED000
load hkmem end*
----------hkmem_load success ----------
----------<1> tar sys_app ----------
[ 10.897149] DWC_ETH_QOS fcc00000.eth0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
decompress sys_app done.
----------<2> tar guir webs ----------
decompress gui_res done.
decompress webs done.
EP cmdline will change to:" console=ttyS0,115200 pdbg=4 mem=148M console=shmtty0"
[Platform:na51039]Found devices cnt[1] bitmaps[0x2].
[EP1]Probed PCIe ...
ioctl setting ep tags failed !, errno=22
[EP1]start successfully!
Boot GM8316(83160004), ,
DS_72_78_08HUH_M
chipid is 8316
devType is af37
ddr name: frammap0(mtype: cma_mem)
chipid: 0
ddrid: 0
base: 0x6800000
end: 0x8000000
memory allocated: 0x0 bytes
memory free: 0x1800000 bytes
max available slice: 0x1800000 bytes
memory allocate count: 0
clear address: 0x6800000
dirty pages: 0
clear pages: 6144
size alignment: 0x1000
global DDR mapping:
Global DDR:0 ==> chip0, local ddrid:0
Global DDR:1 ==> chip0, local ddrid:1
Global DDR:2 ==> chip1, local ddrid:2
Global DDR:3 ==> chip2, local ddrid:3
Global DDR:4 ==> chip3, local ddrid:4
hdal_base: 0xc000000, hdal_size: 0x34000000
loadAd tp2823:0,tp2833C:0,tp2827C:0,tp2828:0,tp2830:0,tp2831:0,nvp6134:0,nvp6134b:0,reg_fe:0,reg_ff:0
load ad err
cmdBuf:insmod extdrv/tp2823.ko
- ATTENTION!! PLEASE READ THIS NOTICE CAREFULLY ! *
- Don't power off or anything that interrupt it ! *
- The upgrade process will finish in 3 minutes ! *
- If this program fails, machine might be unusable ! *
Writing ...
Done
Checking ...
Done
SPI NAND
Flash ID read done
Normal Boot
Enter Loader
WATCHDOG RESTART
Version 0.3.8
done
DDR1 1800 2Gb
Done
Starting kernel ...
bootpart :0
Protect Shell (psh)
nfsdir: kdbg:1
language is 1
load hkmem start*
af37
DS_72_78_08HUH_M
load hkmem end*
DS_72_78_08HUH_M
chipid is 8316
devType is af37
chipid: 0
ddrid: 0
base: 0x6800000
end: 0x8000000
dirty pages: 0
clear pages: 6144
global DDR mapping:
load ad err
