Hi there,
I've moved my installation from my 6yr old server to my 2 day old pc!
Have connected 3 4mp IP cameras and the load is happily at 45%.
I used a backup of the previous configuration to get up and running quickly - I'm wondering if this has caused problems?
The problem is that clips appear in the list twice. The clip marked "external" does not open - as in the example.
The clip marked "bvr H264 New" is ok.
If I rebuild the database the "external" clip vanishes, and the others play ok.
Any ideas what I've setup incorrectly? It happens on all cameras.
Thanks in advance!
Thanks in advance!
