Dual Lens China Camera with rtsp access
pepoteto
Nov 12, 2022
3
Spain
Hello I bought an China Camera ipc365 camera dual lens Model 8M4K-1FWW or WP606 and when accessing from the pc through rtsp I see only one of the cameras, camera r, do you know how you can access both at the same time? With the mobile application makes you a united composition.
I try all. rtsp:/admin:[email protected]/, rtsp:/admin:[email protected]/onvif1, rtsp:/admin:[email protected]/onvif2, and a long etc. I think i probe all modes of ispyconnect for IPC365 cameras.
Thank.
yes, i asked, but the chinese told me than only it can be seen with the mobile, but this is not true, the camera has open ports 8080 (onvif) y 554 (rtsp)
I have the same camera and the same problem
rtsp:/<ip-address>:554
works fine for streaming camera 1, but I have not been able to figure out how to stream camera 2 or the unified/combined stream
anybody?
Thank.
How do I know what is the IP for rtsp and does it have a password?
Thank.
ICSEE app? My Anjvision using AC18pro app can stream a wide angle view of both camera stitched together with no issue but sometimes the stitching have some flaws.
FYI - dual lens cameras may appear as 2 separate streams for some programs ..
nmap could be useful here to do a scan ..
Hello!
What url do you use for rtsp?
I am connected by access point. The IP is 192.168.233.13 and the port is 23456 (search with nmap) but not if it is correct
Hello,
Using debug in ONVIF Device Test Tool I got two streams rtsp:/192.168.0.X:554/realmonitor?channel=0&amp;stream=0.sdp and rtsp:/192.168.0.X:554/realmonitor?channel=0&amp;stream=1.sdp (double / in rstp:/)
Nmap: (nmap -p- -sV -sC -O 192.168.0.X)
Code:
Nmap scan report for 192.168.0.X
Host is up (0.0091s latency).
Not shown: 65533 closed tcp ports (reset)
PORT     STATE SERVICE    VERSION
554/tcp  open  rtsp
| fingerprint-strings:
|   FourOhFourRequest, GetRequest:
|     HTTP/1.1 200 OK
|     Content-Length: 0
|     Content-Type: application/x-rtsp-tunnelled
|     Server: Puwell RTSP Server
|     Connection: close
|     Cache-Control: private
|   HTTPOptions, RTSPRequest:
|     RTSP/1.0 401 Unauthorized
|     Content-Length: 0
|     WWW-Authenticate: Basic realm="PuWellRtsp"
|   SIPOptions:
|     Content-Length: 0
|     Cseq: 42 OPTIONS
|_    WWW-Authenticate: Basic realm="PuWellRtsp"
|_rtsp-methods: ERROR: Script execution failed (use -d to debug)
8080/tcp open  http-proxy Private-Webs
|   FourOhFourRequest:
|     HTTP/1.1 404 Page Not Found
|     Server: Private-Webs
|     Date: Sun May 14 03:59:38 2023
|     Pragma: no-cache
|     Cache-Control: no-cache
|     Content-Type: text/html; charset=utf-8
|     <html><head><title>Document Error: Page Not Found</title></head>
|     <body><h2>Access Error: Page Not Found</h2>
|     <p>Cannot open URL</p></body></html>
|   GetRequest:
|     HTTP/1.0 302 Redirect
|     Date: Sun May 14 03:59:37 2023
|     Pragma: no-cache
|     <html><head></head><body>
|     This document has moved to a new <a href="http://DVRDVS:8080/index.asp">location</a>.
|     Please update your documents to reflect the new location.
|     </body></html>
|   HTTPOptions:
|     HTTP/1.1 400 Bad request
|     Pragma: no-cache
|     <html><head><title>Document Error: Bad request</title></head>
|     <body><h2>Access Error: Bad request</h2>
|     <p>Bad request type</p></body></html>
|   RTSPRequest, Socks5:
|     Pragma: no-cache
|_    <p>Bad request type</p></body></html>
| http-title: Document Error: Page Not Found
|_Requested resource was http://192.168.0.X:8080/index.asp
|_http-server-header: Private-Webs
MAC Address: E0:51:D8:XX:XX:XX (Unknown)
Device type: general purpose
Running: Linux 2.6.X|3.X
OS CPE: cpe:/o:linux:linux_kernel:2.6 cpe:/o:linux:linux_kernel:3
OS details: Linux 2.6.32 - 3.10
Hello,
Code:
554/tcp  open  rtsp
|     HTTP/1.1 200 OK
|     Content-Length: 0
|     Connection: close
|     Content-Length: 0
|   SIPOptions:
|     Content-Length: 0
|     Cseq: 42 OPTIONS
|   FourOhFourRequest:
|     Pragma: no-cache
|   GetRequest:
|     Pragma: no-cache
|     </body></html>
|   HTTPOptions:
|     Pragma: no-cache
|     Pragma: no-cache
Thanks @rtsp
Hello,
"Using debug in ONVIF Device Test Tool I got two streams rtsp:/192.168.0.X:554/realmonitor?channel=0&amp;stream=0.sdp and rtsp:/192.168.0.X:554/realmonitor?channel=0&amp;stream=1.sdp (double / in rstp:/)
Nmap: (nmap -p- -sV -sC -O 192.168.0.X)"
Code:
note - website here strips the extra "/" as mentioned .. so remember to add the extra "/"
Thank.
HI,
How did you manage to access via RTSP? I have the same camera, I had to do the initial configuration with the IPC360 application, I had to create an account, my username is an email address. I understand that I cannot put this account in the format rtsp:/[email protected]:[email protected]...... because the first @ causes a conflict.
How did you proceed?
Thank you
The login email and the login for this stream is usually different. The rtsp login username is usually "admin" and the password would be one that you set separately or by default the verification code of your device.
Hope this helps
