DT087G2 whats default password?
wozzzzza
Pulling my weight
Jan 5, 2015
497
114
trying to change some of the default setting in my new DT087G2 camera i just got today using the SADP and its not working. says wrong password. tries 12345, 123456 says its wrong, what is it??
Is that a Hikvision OEM model?
If so -
Did SADP initially show the status as 'Inactive'? Then 'Activate' it by creating your own password.
Suggestion :
The specs suggest it has a reset button (usually under the SD card hatch).
Use that to reset to 'Inactive' and activate it using SADP.
while it is an OEM one, no logo, it starts as active in sadp. pressed reset and it reset, still starts as active.
now its got an IP on my network subnet, i can get tot he page of login with browser but dont know password.
