Hi folks,
I have an old DSC Power632 /PC 1555 security alarm system.
Somehow I've ended up arming it after recent power outages in Texas. I don't know the master/installer/access code. I am the second owner of the house.
So I can't seem to disarm it now.
The burglar alarm goes up loudly every time front/back door are opened.
Its very annoying. I just disconnected the alarm/siren to cut the noise.
I guess my only option is to replace the panel? Is that right? Will that fix it?
If I do need to replace the panel, could someone suggest a compatible panel I can buy? Would I be able to do it myself?
Can I still keep the other half of the system ( the box, wiring and battery) located in my closet?
Any help is appreciated. Thanks in advance.
