Hi All
I have a DS-7608NI-SE/P NVR with a handful of Hikvision cameras. The cameras remain on the network rock solid but the NVR repeatedly and sporadically drops its connection to the LAN on a frequent basis (every day or so).
I have run out of ideas as to what it could be, so far trying:
Only way to get the NVR back online after an episode is a hard reset
Any ideas.....or should I give up and get another NVR. If so what would folk recommend? I would be happy with HIKVISION if the NVR worked but am not wedded to them.
Thanks in advance....
- Upgrade HDD to a WD Purple Drive
- Change Router to new one
- Change Router to a different model
- Removed any Powerline adaptors and installed ethernet direct to router
- Restricted DHCP table on router to 50-199 ip address range and assigned NVR an IP address outside of this (in case there were DHCP clashes with the static IP address
- Updated firmware to V3.0.22 build 170621
