Hi.
I have ip cam system with ~8 cameras. All are HikVision DS-2CD2x32.
Everything worked for some time (4 months), after that time one of cameras began to reboot.
It works for 10 minutes, gives image, etc, then reboots, 1 minute of boot, works for 5-10 minutes, reboots, etc.
I replaced this camera with new one and forgot about the problem, but after next few months it started to do the same.
This is the second camera failing in the same way.
It is connected to professional poe switch (port 13, heh), in the same way as all other cameras.
I did no firmware changes to cameras.
What can be the cause, how can i fix the camera?
Best regards,
peku33
Best regards,
peku33
