Hello!
Is here anyone who can help to downgrade firmware V5.4.3 build 170519 (OEM) on hiwatch DS-I114?
This firmware is oem and locked to their cloud (our local internet operator). I wanted to try, they give me custom firmware. All is fine, but... freedom must be forever.
But they not tell about not changeable... oh, oh...
Now i cannot change anything. Web interface is unreachable, command interface on 8000 not responding.
There, probably, is used other protocols for command interface, or ip filter.
Supports (local oem and local hik) said that it is not possible to backing to stock firmware. I am not believe them... They want money, probably.
By tftp camera is taking firmware, but nothing changing - oem custom firmware staying.
Tried for several others - not affecting.
By SADP it is able to change admin pass (by xml-file and support). Then i can change web port, e.g. 81 - web staying is reachable, but answer: document not found. Perhaps, web scripts are moved or absent.
If i change 8000 port to other (e.g. 8100, 8500) - no connect anyway.
Here is the link to this firmware: digicap.dav — Yandex.Disk
Is there a way to help me?
