- Jul 12, 2015
- 79
- 40
Had a question about some specs on this DVR.
The place where I work is looking to upgrade security systems and the contractor proposed a Hikvison DS-9008HWI-ST system to get away from their current Analog Everfocus system with some 1.3MP 720p IP cameras. I read the specs on the DVR but I'm a little unsure about its specs and whether or not it's a true HD DVR. http://overseas.hikvision.com//uploadfile/image/20150705115236710.PDF
It states in the specs that encoding resolution at Main Stream goes no higher than WD1 (960H), yet playback resolution is in all kinds of resolutions like 5mp, 3mp, 1080, 720, etc.
The reason I'm confused is at my own home I have a Turbo HD DS-7208HGHI-SH system, an HD-TVI system. So I'm not familiar with the capabilities of an IP system. But in its encoding, it plainly says that it records in 1080p and 720p HD and playback also in 1080p and 720p.
Is the DS9008HWI system good for HD or should I recommend another DVR?
