We installed a DS-7716NI-SP/16 NVR with 15 cameras at a remote location. We are going to be using iVMS-4200 software to access the NVR. My question is how can we use the users that we created in the DS-7716NI-SP/16 NVR as the login users in iVMS-4200. We will have multiple machines with iVMS-4200 installed on them, and would rather not have to create the users on each. It appears the username the iVMS-4200 uses has no correlation with the users on the NVR.
Anyway around this? I know I can create the users in one iVMS-4200 and export it and import into other machines, but that doesn't scale very well if we had other users or modify a user.
Thanks in advance
Thanks in advance
