DS-7608NI-SE/P wont connect to camera
Billkater
Jul 5, 2014
87
5
Hello all.
I have the DS-7608NI-SE/P nvr with 5 cameras connected to it. I am trying to add a new camera, a DS-2CD2442FWD-IW. The NVR is listing the camera as Offline(Network Abnormal). At one point I thought the Offline status was replaced with stream not supported, but am not able to reproduce that status.
I have pictures of the nvr and camera setup screens attached. This is a wired camera, not using WiFi.
42580268_2174190949572318_2949384699639758848_n.jpg 42423066_2152468544992738_1453001244556656640_n.jpg 42434912_2004251742944714_2264465702305923072_n.jpg 42385558_647365345664620_8009208632228970496_n.jpg 42416668_326971841401220_145080340241711104_n.jpg 42450586_313022185943456_1234018776442208256_n.jpg 42543831_236368030388305_9198079854916927488_n.jpg
Suggestions?
Thanks
Bill
I am assuming you have activated the camera via sadap and it gave you the 192.168.1.106 ip is dhcp now off,untick the box
And the password you set was the same as the nvrs.?
Go to camera management and manually add the camera, not plug and play.
Click on modify enter the IP address
Then admin
Then the camera password
Hit refresh on the web browser and it should come up if it says stream not supported that’s usually due to encryption being on
Then admin
Yes. Camera setup and works via firefox. I changed to static ip. Put camera password in nvr. When I am there tomorrow I will double check everything on your list just for sure and report back.
Sent from my SM-G920V using Tapatalk
I swapped out some old switches that were flakey for new gigabit ones. Connects now with no problems.
Only problem.now is my NVR won't show a picture when multiple streams are up. I am starting a new thread for this though.
Thanks
Bill
