Greetings folks,
I recently upgraded my DS-7608NI SE/8P to v2.3.12 and R0 Series DS-2CD2732F-IS cameras to IPC_R0_EN_STD_5.4.5_170401 using brickfixv2 process posted in this forum (great document - Thank you!!!).
Interestingly enough the NVR see my other three cameras with no issues except for the aforementioned version.
I can get to them and see the "Live View" by login in directly via the browser but I can't from the either IVM or NVR directly. Multiple attempts to setup on the NVR have proven unsuccessful.
I am curious if that is because the NVR is checking for "language" version...which it would be odd since the other cameras (DS-2CD2145F-IS & DS-2C2732F-IS), are Chinese (S/N ...CCCH5...) and I had no setup issues....well I did noticed one issue on my NVR. Mainly that the Ethernet Ports are not properly enumerated (e.g, Port#8 is just below Port#1 and not as in the label, etc.).
I would appreciated if anyone knows for sure if the issue is due to the NVR not able to detect the DS-2CD2732F-IS on 5.4.5.
Your time, attention and support is greatly appreciated and I look forward to any replies.
Thanks,
George.
Thanks,
George.
