- Oct 20, 2015
- 47
- 2
It seems my ds-7608ni-e2 is at the end up it supported shelf life, so I am wondering if I can just get a newer motherboard and slap it in the existing case?
I had to open the case up since the unit started beeping ( guessing the HD is going bad ) so I am doing a low level WD uty format and then I will try it starting it up again before I go out and order another 4TB HD, but looking inside the motherboard is like 8" x 6" and I thought maybe I can just find a fewer model motherboard and swap out, and so here I am asking the pro's..
Can it be done and if so where should I look for a newer model replacement MB
Thanks,
Thanks,
