I've managed to update it to the latest firmware that I've found 2.3.12, and I'm trying to setup ddns.
It doesn't support hikconnect so I'm trying to use another provider such as no-ip.
On the UPnP ports page on the NVR the ports are marked as "Not Valid" (they are all default).
I've checked on the router (Verizon Fios 3100) and the UPnP is enabled. The NVR is the only device connected to the router.
What more can I check to make this work?
