- Mar 18, 2017
- 61
- 5
DS-7108N-SN/P
V3.0.10, Build 141201
V5.0, Build 141127
I have the above NVR, should I upgrade the firmware?
I'm aware there are much newer versions available, but I'm mindful that the product code is not for the international version, and I don't want to end up bricking it.
I haven't checked the camera versions yet, but I think they are international, so not so much of an issue.
Would you recommend upgrading?
If so, to which version?
And could you provide a link?
Many thanks.
V5.0, Build 141127
Many thanks.
