Hi all,
Seek you all help and advice.
I have a unit of DS-7108-SN/P, connected to 4 unit camera, 2 unit are ip camera, direct connect to NVR using network cable ( Cam 1 and 2 ), another 2 unit are connected using wifi, on cam 3 and 4. I having issue when viewing thru ivms-4500 on the android phone (4g), only can stream cam 3 and 4, but cannot view cam 1 and 2. this also happen when viewing on home wifi too.
my local network ip set on the router are 192.168.0.1 range, nvr had set the fix ip of 192.168.0.99, and nvr built in network port range are using 192,168.1.1. both cam 1 and 2 that connected direct to nvr and using fix ip on 192.168.1.101 and 192.168.1.102. and for the wifi cam 3 and 4, both are connect to my wifi with fix ip of 192.168.0.104 and 192.168.1.105. i had doing the port forwarding on port 80, 8000, 554, 443, 8200 and also 9010 and 9020 too to nvr ip 192.168.0.99 and also DMZ on this ip too. And nvr are connected to hiddns.
when direct connect to tv, there are no problem on viewing 4 cam, can i know is there any setting i miss out, and also any solution on this, thanks
