Has been working fine for months. Unit lost power, and on return it reboots with a single beep every few minutes. Have tried flashing again (as have done before) but keeps resetting. Has flash chip died?
Can login to admin console breifly until it reboots. Connecting to serial ttl reveals:
Code:
U-Boot 2010.06-svn18487 (Nov 11 2017 - 13:44:08)[V1.4.5]
Hit ctrl+u to stop autoboot: 0
### CRAMFS load complete: 3499032 bytes loaded to 0x82000000
## Booting kernel from Legacy Image at 82000000 ...
Verifying RSA ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 1.983057] init(1) called reboot syscall, cmd: 0x0.
Thu Jan 1 00:00:01 UTC 1970
mv: can't rename 'ubi*': No such file or directory
Starting udev: [ OK ]
/usr/bin/hrsaverify: verify "/tmp/start.sh" success!
/usr/bin/hrsaverify: truncate "/tmp/start.sh" to 5904(1710 hex) success!
sdbg: serverip:192.0.0.128
fastboot is
language is 1
devtype is acfd
----------<1> tar guir webs ----------
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# [ 4.996262] hi_gmac_v200 100a0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
----------<2> show logo ----------
mv: can't rename '/home/app/exec/ss': No such file or directory
chmod: /dev/ttyS3: No such file or directory
read: pDevCfg->cfgHead.paraVersionis [0x170816];
read: iCkSum is [0x82d]; pDevCfg->cfgHead.paraChecksum is [0x82d]
ERROR this is a new device, please check!!
scriptCmd: ./load -i 0.
a is acfd
DS_7208HQK_K
mmz allot OK DS_7208HQK_K
0x120F0800: 0x00000170 --> 0x00000038
[END]
0x120f084c: 0x00000170 --> 0x00000038
[END]
close tde alpha filter
loadAd tp2823:0,tp2824:0,tp2833C:0,tp2827C:1,tp2828:0,nvp6114a:0 nvp6124b:0 nvp6134:0,nvp6134b:0
cmdBuf:insmod extdrv/tp2823.ko
insert audio
load K72 ok
----------<4> del no use res ----------
cp: can't stat '/home/app/hisi/modules/setDebug_mux': No such file or directory
iSCSI daemon with pid=293 started!start savelog proc!!!!!
pdev_hard_info->ataCtrlNums=1
file:src/pal_api.c,line:574, pal_module_init successfully
[CRIT]read_execl_guide_cfg()1157:start
[INFO]get_flash_cards_info()410:ignore [msmouse].
[CRIT]get_flash_cards_info()451:********can not find any usb device!********
[CRIT]read_execl_guide_cfg()1167:get flash cards info failed. iRet[-1]
read execl guide cfg failed. iRet[-1]file:src/pal_api.c,line:535, pal_module_init has been called
remove error
hisi_bsp_info_close[1]
:0
t1: wait storage [2] and gui[2] and hicore[2] and ipcm[0] and toolserver[0]
fun:hisi_watchdog_init, line:5486 hisi_watchdog_init(/dev/watchdog, 28) ok iDogTimeOut:25 Sec!
/*********************init_global_error_lib*/, init_global_error_lib start!
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~phy on eth0 is link up
-----------------get_net_link status == 1
:0
init_lzma_mem alloc size 1048576
initNetIf set_eth_mode start ========
dns handle set eeeeeeeeeeeeeeee
RTNETLINK answers: No such process
RTNETLINK answers: No such file or directory
fun:hisi_dsp_init, line:2819 --------------init dsp --------------------
fun:hisi_main_dsp_init, line:1990 Device Main Vo Chan is 2[0]
menuDispChan = 0
[ 15.290702] hi_gmac_v200 100a0000.ethernet eth0: Link is Down
[ 17.386880] hi_gmac_v200 100a0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
111vcaVpssGroup = 11
111vcaVpssGroup = 12
<DSP>vca DspVcaInitOsd OK!
<DSP>vca Init vca success
<DSP>vca DspVcaInitMetaDataPack: ok
<DSP>vca DspVcaScdInit chanNum = 2
<DSP>vca scdChan:0
<DSP>vca scdChan:1
<DSP>vca DspVcaScdInit OK!
<DSP>vca smdChan:0
<DSP>vca smdChan:1
hisi_main_dsp_init:DSPINITPARA=3108608
************g_pDspInitPara[0xb4ad7008], menuShareBuf 0[0xb4b470fc, pAddr=0xa10de000, vAddr=0xabd7a000, w:1920,h1200,p:1920] 1[0xb4b47110, pAddr=0x0, vAddr=0x0, w:0,h0,p:0],
hisi_freelogo_buffer is succsse 0
fun:hisi_dsp_init, line:2840 ------ dsp is init Ok iRetVal:0---------
!!!!!!!!!!!!!!!!!!!!!!!!!DSP Init Ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
fun:hisi_fill_4_screen_param, line:1739 window dispInfo[w:1280, h:1024], step(640, 512), last(640, 640)
init_stream_buf, pInStreamBuf:0xa94ce008, pOutStreamBuf:0xa954e008
------------> pthreadSpawn handle_pppoe_cfg_cmd
===================handle_pppoe_cfg_cmd=====================
=============pppoe============FOREVER=====================================
:0
part /dev/sda stor_get_db_total_files alloc 465 byte mem.
:0
part /dev/sda stor_get_record_file_detail_task beging 1568639566
t1: wait storage [0] and gui[2] and hicore[0] and ipcm[0] and toolserver[0]
maxIPCcount[0] maxAnalogCount[4]
Load image error.
part /dev/sda stor_get_record_file_detail_task ending 1568639572
t1: wait storage [0] and gui[0] and hicore[0] and ipcm[0] and toolserver[0]
big_bit_mask p[0xa9488708], idx[-1] error!func[big_bit_mask],line[63]
[09-16 13:13:01][3][488]RemoteSession::~RemoteSession()
[09-16 13:13:01][3][488]RemoteSession::Free
[09-16 13:13:01][1][488]p2pLinkManage Destruct Ok
[09-16 13:13:01][2][503]check remote session thread begin
tttttchan=1,vaddr=0xb4a55000
file[init/dvr.c],func[setSubStreamRecStatus],line[2003], iChan:[1],iRec:[0],iSubRec:[0]
file[init/dvr.c],func[setSubStreamRecStatus],line[2004], iChan:[1],szRecCount:[1],szSubRecCount:[0]
tttttchan=2,vaddr=0xb49d2000
file[init/dvr.c],func[setSubStreamRecStatus],line[2003], iChan:[2],iRec:[0],iSubRec:[0]
file[init/dvr.c],func[setSubStreamRecStatus],line[2004], iChan:[2],szRecCount:[1],szSubRecCount:[0]
tttttchan=3,vaddr=0xb3ff7000
file[init/dvr.c],func[setSubStreamRecStatus],line[2003], iChan:[3],iRec:[0],iSubRec:[0]
file[init/dvr.c],func[setSubStreamRecStatus],line[2004], iChan:[3],szRecCount:[1],szSubRecCount:[0]
tttttchan=4,vaddr=0xb3c71000
file[init/dvr.c],func[setSubStreamRecStatus],line[2003], iChan:[4],iRec:[0],iSubRec:[0]
file[init/dvr.c],func[setSubStreamRecStatus],line[2004], iChan:[4],szRecCount:[1],szSubRecCount:[0]
@@@@do not need poc test@@@@
!!!!!!!!!!!!!!!sc_hicore is start ok!!!!!!!!!!!!!!!!
read_rs485: recv data 1
Device Is Ready
$$$$$$$$$$$$$ iAoChans[4] $$$$$$$$$$$$$
g_aoChan[0]=[2]
+++++++++++++++++++First save_error_no, time_t:1568639549
==============proc_cmd_data start iSock [190]
==============>>>>iCmd:0x100,rlen:4
>>>>>username:,passwd:,enable:0,ifname:eth0
remove pppoed!
==================enablePPPoE failed!!!
stor_check_smart iDeviceStatus 0
===>watchdog ERR:chan[3] 5 minnutes no stream!!!
1+0 records in
1+0 records out
65536 bytes (64.0KB) copied, 0.005794 seconds, 10.8MB/s
[ERROR]:savelog.c[1140] iCurrTime[1568639636] iTempTime[1568637002]
[ERROR]:savelog.c[1435] flash can not be Operate and quit!
[ERROR]:savelog.c[1469] flash can not be Operate and quit!
[ 110.676039] dvr_main_sc300 (519) called reboot syscall, cmd: 0x1234567.
[ 110.683487] reboot: Restarting system
