Hello,
Between a friend of mine and I we have four of these cameras, two of each. All updated to latest fw V5.6.15 build 191211
I noticed that in the Smart Event section, under "Intrusion Detection", "Line Crossing Detection", etc, there is no buttons "min size" and "max size" to draw the minimum and maximum size of the object to detect.
I can set the size of the area to monitor, the sensitivity and the threshold as in my other different models of cameras, but with these I am detecting a lot of unwanted events because of very small insects flying in the field of view.
Typically you would solve this problem by drawing a "min size" rectangle a bit smaller that the smallest object you want to detect, say a person.
I have these buttons in all my others 20+ hikvision cameras, why not in these ones?
Mind that we are talking 4 different cameras accessed via different computers and browsers (IE11, Chrome with ietab extension) and they all show the same issue. I haven't tried older firmwares.
Do any of you have these cameras, can you check if you have these buttons and report your fw version?
