DS-2DE2A404IW-DE3 built-in microphone?
Jul 4, 2015
27
4
I purchased a bunch of DS-2DE2A404IW-DE3 cameras the other day. Per the specs on the website: DS-2DE2A404IW-DE3/W|Value Series|Hikvision . They list the cameras as having a mic line in, line out and "built in mic" . I am on the current firmware and when I go to the configuration settings and then audio there is no option to select the "built in mic", there is only a "line in" option. I did enable Video and audio on both the main stream and sub stream but it appears that the camera does not come with a built in mic. Is this correct or am I just going crazy?
Question number 2:
If there is no built in mic i was looking at adding a few of the DS-2FP2020 active mics. My plan is to split the POE connection at the camera and tap the power for the mic. My plan is to use these adapters to make it work. Can anyone advise if this would work?
Connect this to the POE line:
then use this to split to POE for the camera and a barrel adapter for the Mic:
Then this to break out the barrel adapter cleanly:
