Hi,
I received a DS-2CD7283F-EIZHS from Ali-Express / v5.1.0 chinese firmware, english menu.
Firmware is different than 2732, then Hikvision support gave me another string value to modify (for fixing NFS NAS issue). Unfortunately, I didn't find this value in davinci => I think I have previously install english firmware.
I downloaded this firmware from here => http://www.hikvision.com/en/download_more.asp?id=1347
Problem, I can't flash with tftp method (as I usually did for my DS-2CD2732), it stops here :
Do you have an idea of the problem ?
- Protection on this hardware from changing region firmware ?
- File isn't compatible with this cam ?
- Did I missed something ?
If I can't fix NAS issue, I will return this materiel for refund.
Thank you for your help !
Code:
[2014-05-14 22:31:44] Device[192.0.0.64] test tftpserver
[2014-05-14 22:31:44] Connect client[192.0.0.64] success
[2014-05-14 22:31:44] Start file[C:\TFTP-Auto-Update\digicap.dav] transmitting
[2014-05-14 22:31:54] Completed file[C:\TFTP-Auto-Update\digicap.dav] transmit
