- Aug 10, 2015
- 18
- 2
Hikvision’s : License Plate Recognition (LPR)
The LPR module not only reads and recognizes license plate information automatically from passing vehicles, but it also logs the information with the accompanying snapshots. All of this vehicle information is searchable using time or license plate information and it can then be transmitted to multiple users simultaneously. The LPR module is effective to enforce parking permits or time-limited zone rules and to conduct lot inventories. The software already support optimized recognition algorithms for more than 50 countries around the world and has been used for a variety of private and commercial applications. Hangzhou Hikvision Digital Technology Co. Ltd.
The Dark fighter series ultra-low light ANPR cameras are able to capture high quality colored images in dim light environment. DS-2CD4A26FWD-IZ(H)(S)/P offers Full HD resolution with up to 60fps high framerate, 120dB WDR, PoE, Defog, 3D DNR and complete Smart Feature-set to meet a wide variety of applications.
 1/1.8” Progressive Scan CMOS
 Full HD1080p video
 Up to 60fps framerate
 Ultra-low light
 120dB WDR
 3D DNR
 Motorized lens with Smart Focus
 -H: built-in heater
 -S: audio/alarm IO
 Support 128G on-board storage
 DC12V/PoE
 IP67
 Build in 4 EXIR LEDs
2MP Low Light ANPR IR Camera
DS-2CD4A26FWD-IZ(H)(S)/Pis Hikvision ANPR IPC and features complete Smart functions including:
ANPR function
Vehicle Detection with Automatic Number Plate Recognition,
Build in IR LEDs for color day video/BW night video.
Smart Image Control
Key Features
Smart
l Smart lens options: AF lens
l HD 1920 × 1080@30fps
l Supports image distortion correction
l Support rotate mode, suitable for environment as corridor.
l Support regional cropping, details can be seen with low bandwidth.
l Code smoothness setting for different requirements of image quality and fluency.
l Support H.264/MPEG4/MJPEG video compression, multi-level video quality configuration; support Basic/Main/High Profile H.264 encoding complexity.
l Multiple OSD color: Black & white self-adaptive; Custom
l WDR is supportable for backlight environment.
l Support defog, EIS.
Infrared
l IR anti-reflection panel, increase infrared light transmittance.
l Smart IR, prevent over-exposure in close distance
System
l Support ONVIF (profile S/profile G), CGI, PSIA, ISAPI protocol.
l Support three streams, and Support 20 channels live view at the same time.
l AF automatic fast focus, maintain focused during zooming
l Anti-thunder, anti-surge, anti-static, IP67 protection level.
Interface
l Support standard 128G Micro SD/SDHC/SDXC card storage.
l Support 10M/100M Ethernet Port.
l Support Audio I/O, support dual channel stereo audio.
l Support Alarm I/O
l Support CVBS analog output
Security
l Support three-level user authentication management, user and password authorization, IP address filtering and anonymous access.
l Support security certificate as HTTPS, SSH; support creating certificate.
l Basic and digest authentication is supportable in IE configuration
l Lock user IP for many times error login
Specification
Camera
Image Sensor
1/1.8’’ Progressive Scan CMOS
Min. Illumination
0.002 Lux @ (F1.2, AGC ON), 0.0027 Lux @ (F1.4, AGC ON), 0 Lux with IR
Shutter Speed
1s ~ 1/100,000s
Slow Shutter
Support
Lens
2.8~12mm @ F1.4, angle of view: 92°~32°
8~32mm @ F1.4, angle of view: 50.4°-15.7°
Lens Mount
AF automatic focusing and motorized zoom lens
Auto-iris
DC drive
Day & Night
IR Cut Filter
WDR
120dB
Compression Standard
Video Compression
H.264/MPEG4/MJPEG
H.264 Type
Baseline Profile / Main Profile / High Profile
Video Bit Rate
32 Kbps –16 Mbps
Audio Compression
G.711/G.722.1/G.726/MP2L2
Audio Bit Rate
64Kbps(G.711) / 16Kbps(G.722.1) / 16Kbps(G.726) / 32-128Kbps(MP2L2)
Max. Resolution
1920 ×1080
Frame Rate
50Hz: 25fps(1920 × 1080,1280 × 960, 1280 × 720)
60Hz: 30fps (1920 × 1080,1280 × 960,1280 × 720)
Image Enhancement
3D DNR/ROI/Defog/EIS
Image Setting
Rotate Mode, Saturation, Brightness, Contrast, Sharpness adjustable by client software or web browser
Regional Cropping
Support
Distortion Correction
Support
Day/Night Switch
Auto/Schedule/Triggered by Alarm In
Picture Overlay
LOGO picture can be overlaid on video with 128x128 24bit bmp format
Network
Network Storage
NAS (Support NFS,SMB/CIFS), ANR
Alarm Trigger
Motion detection, Tampering alarm, Network disconnect, IP address conflict, Storage exception
Protocols
TCP/IP, UDP, ICMP, HTTP, HTTPS, FTP, DHCP, DNS, DDNS, RTP, RTSP, RTCP, PPPoE, NTP, UPnP, SMTP, SNMP, IGMP, 802.1X, QoS, IPv6, Bonjour
Security
User Authentication, Watermark, IP address filtering, Anonymous access
Standard
ONVIF(PROFILE S,PROFILE G),PSIA,CGI,ISAPI
Interface
Audio
(-S 1-ch 3.5 mm audio in(Mic in/Line in)/out interface
Communication Interface
1 RJ45 10M/100M Ethernet port;
Alarm
(-S 1input, 1 output (up to DC24V 1A or AC110V 500mA )
Video Output
(-S 1Vp-p composite output (75 Ω/BNC)
On-board storage
Built-in Micro SD/SDHC/SDXC slot, up to 128GB
Reset Button
Yes
 Full HD1080p video
 Ultra-low light
 120dB WDR
 3D DNR
 -H: built-in heater
 -S: audio/alarm IO
 DC12V/PoE
 IP67
ANPR function
Smart Image Control
Key Features
Smart
Infrared
System
Interface
l Support Alarm I/O
Security
Specification
Camera
Image Sensor
Min. Illumination
Shutter Speed
1s ~ 1/100,000s
Slow Shutter
Support
Lens
Lens Mount
Auto-iris
DC drive
Day & Night
IR Cut Filter
WDR
120dB
Video Compression
H.264/MPEG4/MJPEG
H.264 Type
Video Bit Rate
32 Kbps –16 Mbps
Audio Compression
Audio Bit Rate
Max. Resolution
1920 ×1080
Frame Rate
Image Enhancement
Image Setting
Regional Cropping
Support
Support
Day/Night Switch
Picture Overlay
Network
Network Storage
Alarm Trigger
Protocols
Security
Standard
Interface
Audio
(-S
1-ch 3.5 mm audio in(Mic in/Line in)/out interfaceCommunication Interface
Alarm
(-S
1input, 1 output (up to DC24V 1A or AC110V 500mA )Video Output
(-S
1Vp-p composite output (75 Ω/BNC)On-board storage
Reset Button
Yes
