D Dutchie30 Getting the hang of it Oct 14, 2014 64 43 Apr 1, 2017 #1 I'm trying to figure out how to rotate the image on my DS-2CD4585F-IZ by 90 degrees. The specsheet says it has "Rotate mode", but for the life of me I can't find it anywhere. Any tips anyone?
alastairstevenson Staff member Oct 28, 2014 16,410 7,175 Scotland Apr 1, 2017 #2 Do you have 'Capture Mode' enabled? I have a vague recollection they may be mutually exclusive.
fenderman Staff member Mar 9, 2014 36,891 21,417 Apr 2, 2017 #4 Dutchie30 said: No, capture mode is disabled. Click to expand... Can you see the option at all? or is it disabled? See also this h.264+ disabling rotate mode. Rotate Mode disabled on hikvision dome
D Dutchie30 Getting the hang of it Oct 14, 2014 64 43 Apr 2, 2017 #5 I can see the "capture mode" option and it's set to "disabled". I'm also not using H264+, just regular H264. My settings:
