- Mar 28, 2016
- 83
- 12
The one I got came with a wall mount plate.
I intend to mount the cameras on indoor walls instead of the ceiling. Drilling is not an option. I will probably tape the mounting hardware to the wall.
What kind of mounting hardware should I get?
Junction box type
L shape
What dimension should I get? DS-2CD3345-I has a diameter of 3.75in (measured) with 2 screws 3.25in apart. I should probably convert it to metric (82mm). So the L shape linked (70.5mm) wouldn't work?
For the junction box type, Diameter: 4.3/4", H:11/4". What does H 1.25in mean? Thickness or distance between screws? I don't mind the mount is a bit bigger/smaller than camera, the only thing I should worry about is the distance between screws, correct?
Junction box type
L shape
