I have purchased from aliexp 2 cam ds-2cd3345-I, a 4mm and a 2.8mm.
The cam 2.8mm has firmware 5.3.6 build 151103
The cam 4mm has firmware 5.3.6 build 151221
the cam to 4MM has a problem, if I change resolution to the cam I have a error, if I change some values to the cam I have a error. I believe that the firmware is corrupt.
The cam to 2.8mm works perfectly
I purchased from another seller ever 4mm equal cam and I have the same problem.
Have you ever?
Is there a way to extract the firmware from 2.8mm and put in a 4mm cam?
Another problem I have with these new cam is that h265 not work on my ds-7604NI-e1/4p with firmware 3.4.2 but h264 work perfectly.
I set the cam with the same password nvr, I set the cam ip 192.168.254.16,
I connected the cam on output poe port to nvr,
I added the cam manually and it works.
if I set h264 works perfectly, if i set H265 says "unsupported type stream"
Have you ever?
