- Jun 9, 2015
- 92
- 4
I'm almost about to buy this camera DS-2CD2132-I from aliExpress in China.
http://www.aliexpress.com/item/Hikv...POE-Power-Network-IP66-Indoor/1871393655.html
When I look at the feedbacks it seems to be ok. But what is your experience with buying from China/AliExpress ?
If I buy it - will it work in iVMS-4200 ? and will the browsermenu only be in Chinese ? The model is a multi-language.
Right now I have the DS-2CD2532F-I 2.8mm which works just fine. Is there a big difference between these two models ?
- Kim -
- Kim -
